When you've altered the coordinate system, say that you've got the z-coordinate facing downward, a mirrored part assembled with Default Constraint in an assembly is placed in regard to the top plane. Hence, the mirrored part is located in the air above the assembly and not in the assembly itself.
The product idea is to let the user choose which plane to mirror the part in when using the command mirror part/mirror assembly.
