Choose default setting of the fit of a clearance hole
When creating a standard clearance hole the default setting is "close fit". As we use, up to 99%, "medium fit" I propose an option which allows you to specifiy the default setting. This option would eliminate a lot of frustration and also mistakes made when the change is forgotten.
3 Comments
PTCModerator
Emeritus
mneumueller
Status changed to: Implementation In Progress
mneumueller
Status changed to: Delivered
developed  in Creo 9.0 and also delivered in Creo 8.0.3.0
See Creo 9.0 What's new information at:  Hole Feature Enhancements (ptc.com)
