We're now using the "Creo Elements Pro 5.0".
In the portion of the CAM, to create a point "GOTO" the tool path,
If you enable the configuration option "enable_classic_nc_steps",
we use the features of the "Classic Turning".
If you get lost in the following "Creo Parametric 3.0" config option "enable_classic_nc_steps" is
So troubled, I want you to leave the function.
For automatic translation, it may be difficult to understand, but thank you.
