Greeting,
This is an enhancement idea for Creo Lathe function. Currently, there is no indicative sign or forced action for “Clearance/ Home point setting” in the Creo NC lathe function.
If users don’t set up “Home point” then collisions will be happened 100% while changing cutting tools in all sequences.
There is why I made this video to warn this issue.
