Clip/Trim Radial Pattern Axis Circle in drawing views
If set drawing option "radial_pattern_axis_circle" is set to "yes", it will display radial pattern axis circle, but for current functionality, unable to Clip/Trim Radial Pattern Axis Circle. When pattern members are not filled on whole circle, it is required to clip/trim Radial Pattern Axis Circle., however workaround from https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS58594 is not suitable for us. Please add this enhancement in Creo 4.0.
5 Comments
Newbie
will be great have something like radial_pattern_axis_ARC, maybe  following circle_axis_offset to line ends
Regular Member
i would like for radial patterned holes axis to stay square with the part, when ordinate dimensioning is done.. the center mark axis is rotated, and not able to be used with the ordinate dimension..
Newbie
Hi Daniel,
try set radial_pattern_axis_circle = NO
Regular Member
thanks gabriel.. that option is not there..  but there is radial_hole_linear.......  that i changed.. see if it works..
Community Manager
