Sometimes, after defining a Combined state with 3D annotations in Creo Parametric, when exporting the assembly to pvz and opening the viewable in Creo View, the combined view opens in a different orientation (translated in Creo View compared to whats defined in Creo Parametric😞
The user opening the same combined view inside PVZ can think its empty or in best case need to translate the combined state to have a correct display !
Can you please Correct this behavior : an orientation defined in Creo Parametric for a combined state should be always exactly the same when reopened in Creo View !
Associated PTC Case : C14627537
Thanks in advance
