The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Combined states order after a STEP AP242 export
When you create a combined states you can rename it and then  put it in a specific order (example : Section - front view - Left view)
But after a STEP AP242 export, combined states are saved in the alphabetical order (example : front - left - section) so the STEP export lose the order we want to display combined states.
Creo should export combined states order correctly with a STEP AP242 export (part of the MBD definition)
3 Comments
JamesAvis
Agreed, STEP should export it as defined, not just geometry and annotations, but states, as well.
OliverHeins
That might be a limitation that is not in the control of PTC. To avoid that we added numbers in front of the name of the combined states.
olivierlp
Community Manager
Status changed to: Archived
