Hello...
The "Delete" command does not appear in the tree submenu functions in many modules "PTC Creo Parametric".
For example in Creo Simulate ... when you want to perform and exploit different simulations ..., functions as "volume region" is not possible to "Suppress" it and retrieve it later .... you can delete only.
It would be possible to integrate this command on all modules PTC Creo or at least, in all modules used more as PTC Creo Simulate
