1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
We're working in the automotive and industrial design. Currently we start using model based definition models.
2. What version of Creo Parametric are you currently running?
Creo 7.0.5.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Request:
Set a edge treatment for all undefined volume edges.
Current situation:
It is not possible to assign semantic edge treatment to model edges.
Desired situation:
Set an edge treatment for common use of all not seperately user defined edges.
Afterwards user defined edge treatments overwrite the comon definition.
Removing the user defined edge treatment restores the common definition.
Defined edge treatments get the attached surfaces as references.
4. What is the use case for your organization?
MBD related topic. Model needs to be machine readable. Edge treatment is missing.
5. What business value would your suggestion represent for your organization?
