The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Common Definition of Surface Finish
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
We're working in the automotive and industrial design. Currently we start using model based definition models.
2. What version of Creo Parametric are you currently running?
Creo 7.0.5.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Request:
Set a surface finish for all undefined volume surfaces.
Current situation:
In order to get a semantic surface finish you need to assign a surface finish to each surface of the model.
If you don't assign a surface finish to a surface you don't have a machine readable surface finish on the surface.
Desired situation:
Set a surface finish for common use of all not seperately user defined surfaces.
Afterwards user defined surface finishes overwrite the comon definition.
Removing the user defined surface finish restores the common definition.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
2 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
Thank you, @J.Wagner, for publishing your several ideas today. However, on this one, we need more information as specified in the form you partially followed here. Please tell us more about question #4 and 5. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
If you haven't already, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
olivierlp
Community Manager
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
