The Compare Parts functionality in Creo Elements/Direct is very powerful. It quickly and acurately shows the differences between 2 parts in 2 adjacent viewports, helped by color coding. It's also easy to take measurements between the 2 parts.
The Compare Part By Geometry in Creo Parametric is unreliable, slow, and hard to use.
It would be great if the Compare-functionality of CED would by copied to Creo Parametric
Thanks, Jaap
