Component repeat should highlight even if only geometry is selected
0 Kudos
When working on an assembly if you select the surface of a component the repeat command is grayed out. You have to either change the filter selection or select the component in the model tree to get the repeat command to be active so it can be selected.
I would propose that if a surface or other geometry of a part is selected that the software should look at the parent component and allow the repeat command to be used even if only the geometry of that component is selected.
