Make config pro look professional with check boxes and TAGS by subject like part, assembly, color dimension ANYTHING WITCH HELPS etc with easy and clear choices
Solidworks is great example for settings
Industry DEFAULT settings should be defined by DEFAULT
Allow to create COMPANY custom settings we could save and use as default for certain company
