Config option for Creo 6 option to make the drawing file name the same as the model name
Starting in Creo 6 a new checkbox was introduced that allows the drawing to take the same name as the primary part or assembly when creating it. Currently if the box is checked it remembers the preference for the session but not after restarting Creo.
This idea is to create a config option so that checkbox can remain always checked.
12 Comments
victorazael_lop
I think this is a great idea for those who want to use the same name for drawing and 3d model, however we do use different names, I am wondering if there is an option to disable this new functionality and avoid user to activate the checkbox.
Chris3
The default is for it not to be checked. There is no functionality for hiding the option.
mganzer-2
8-Gravel
Would love this as a configuration option.
jgoncalves
You can always create a macro to replicate the desired outcome.
Mfridman
OliverHeins
It would be good in any case to have config options to set the default for a checkbox.
In this case we would also prefer to have this always checked. Maybe there should be the following options available:
unchecked = current default behavior
checked = behavior that is subject of this idea
hidden = pre creo 6 (option not available) - but I don't know what the benefit would be to hide the option?
Maybe there would be a use case the it is checked an disabled - so it will always use the model name and it can't be changed.
DomenicLaritz
In the recently released version Creo Parametric 7.0.4.0 there is a new config.pro setting drawing_name_sameas_model_name.
So PTC seems to have listened to our wish! 👍
Mfridman
Hi All and @DomenicLaritz
PTC does listen to you!  I actually picked up this issue directly from this product idea and since it was a low hanging fruit, I asked R&D to implement it.
We do our best to help when possible 😀
Just one correction to @DomenicLaritz  statement above, this new config.pro option "drawing_name_sameas_model_name" is planned to be introduced with Creo 7.0.5.0 and with Creo 8.0.1.0 and it will help you to define the default state of the "use drawing model file name" checkbox, during drawing creation
Best Regards
Michael Fridman
Creo Product Management
Mfridman
Status changed to: Implementation In Progress
DomenicLaritz
@Mfridman, strange is but that the said config.pro setting is already present in the online available CSV file of version 7.0.4.0: Creo Parametric 7.0.4.0 Configuration Options (CSV Format) | PTC
That's why I assumed that you can already set it in this version?!
Mfridman
Hi @DomenicLaritz ,
It was originally planned for Creo 7.0.4.0 but we could not make it eventually on time, hence it was postponed to 7.0.5.0
I think that we may have missed to remove it from the CSV file of 7.0.4.0 . sorry about this confusion
Mfridman
Status changed to: Delivered
Updating the status to Delivered since this option was added to Creo 7.0.5.0 which was released already
