Please add a config.pro option to be able to hide the "Resource center" when launching Creo3.
Even if you have a check box to "not show window again", the resource center will reaper when cleaning WS cache.
We would like to choose to not show this information in our company without having to copy creo_parametric_customization.ui in cache at each Creo3 launch.
Solution suggested by PTC :
Possibility is offered to check box "Don't ask me again".
The configuration settings that you have made will be applied to the current session only.
Do you want to save settings to a configuration file?
Possibility is offered to check box "In the future, do not show this message"
SPR 2845653 / 2239491
Changes related to "Welcome to Creo 3.0" dialog through show me the resource center in the Creo browser when launching check box are not considered when saved to creo_parametric_admin_customization.ui in Creo Param
