Configurable CAD blocks in DWG and DXF formats
I would like to see a set of features in Creo Parametric to allow someone to export the drawing views they setup in Creo as CAD blocks in DWG/DXF format. Case C12996357 describes two issues which were found to be working as designed. Currently, I arrange my drawing views and set an origin in the Creo drawing. Then I export as a DWG or DXF. I am required to open the DWG/DXF in AutoCAD and group each individual view as a block. I also have to name the blocks, which was done in Creo already. During the block creation I also have to identify an origin for each view, which was done in the Creo model using a coordinate system.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
