1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Engineering Services
Designers
2. What version of Creo Parametric are you currently running?
7.0.6.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
I would like to be able to create the decimal places for individual parameters.
I went to sketch an engraving a customer wants on parts and I cannot control the decimal places. I could change the config file but I need different decimal places for different engravings. Picture has example of one, but another might be &etch2[.2]
4. What is the use case for your organization?
Customer requires engravings on parts with as made dimensions
5. What business value would your suggestion represent for your organization?
Eliminate errors when typing in manually, save time as auto update when a copy is created and modified, save time because a long relation is not needed.
