Control the default break width size in a drawing
When creating a break in a drawing, and you specify the leader line on one side of a intersected dimension and the intersected dimension (not the other side), you can't control the default break width. It seems to auto-create a large break. It takes whatever value is in witness_line_offset detail option and has some hard-coded proportional increase from there.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
