Ok, so one of the most glaring limitations of Creo 2.0 is the inability to take a projected, interesected, or imported curve and simply convert into a fully editable construction curve. Coming from Autodesk, being denied this basic function is like working with one hand tied behind your back.
Guys, can you please make this happen in your next Creo release. Its just common sense, and incredibly productive. Can you please add the ability to convert any intersected, projected, or imported curve into a fully editable curve you can build surfaces with. No copy/paste/options nonsense - just a plain convert or duplicate/convert function that creates a new curve.
