When copying features from another model - Paste Special, Advanced Reference Configuration, if the copy feature fails, Creo provides 4 options
1. Quit pasting this feature and continue
2. Keep the already pasted feature and Quit the Paste operation
3. Remove already pasted features and continue
4. Cancel the paste operation
There should be a 5th option: Keep already pasted features and suppress/fail failed features.
This would allow the user to use the failed feature tools to correct the failed features. I use this method to copy chunks of models (multiple features), but when it fails it is usually the feature before the fail that needs to be redefined, but the current interface does not allow me to correct. If I could just keep all of the features but have Creo go into failure mode, then I could redefine the previous feature to correct.
