Copy face set feature to another part
If you create a face set feature you cannot copy it to another part without using the copy faces function, when you use custom features you can select a face on any part to create it, it would be good to be able to do the same when copying user defined features.  It would be even better if you could save a new feature to then create commonly used ones from the custom feature table.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
