Security Alert Log4j Security Vulnerability. Click here to know more.
Copy paste in Pattern table
It would be great to be able to copy a table from a different source (eg MS Excel) and paste it into a pattern table, ie in the pro/table box.
5 Comments
AndyHermanson
You can change the "default" editor from Pro\Table to excel. Thats what we do. But it would be nice to have this as default behavior. Below are the Config options you can change.
!== EDITOR OPTIONS ==
pro_editor_command C:\Program Files (x86)\Notepad++\notepad++.exe
!!!Enables use of an editor other than the system
!!!editor when the option editor has been specified as
!!!the value for the options part_table_editor or
!!!relation_file_editor.
part_table_editor excel
!!!Sets the editor that is used to edit notebook parameter tables.
!!!Protab - Use Pro/TABLE.
!!!Editor - Use the system editor (refer to pro_editor_command).
!!!Excel - Use Excel
relation_file_editor editor
!!!Sets the editor used to edit relations.
ErikClacey
8-Gravel
Excellent Thanks for the tip and the other modification options. I'll try it out and then possibly implement it at the company.
AndyHermanson
Glad i could help.
gwalker
PTCModerator
Emeritus
Status changed to: Archived
