When I insert the parameter jog_dist in the boring feature and the cycle format is couplet, the cl-data is correct.
For some cases it´s necessary to switch to the goto output method.
But then the parameter jog_dist don’t apply in the cl-code.
Please fix this issue; witch is documented in article CS17739
