When a shown dimension (added to a drawing view using Show Model Annotations) is dragged to the opposite side of the part geometry in the view, the witness lines are displayed as though they remain attached to the original points on the part geometry and there will be no gaps between them and the part. However, when dragging a dimension that was created using the Dimension command, the dimension witness lines are displayed with the correct gaps in the new location. Change the behavior of the shown dimension to be the same as that of the created dimension so that the gaps are correctly displayed once the dimension is place in its new location.
