Currently a cosmetic sketch is hidden when behind another component in a 3D assembly displayed as shaded. A view of that same assembly paced on a drawing displayed as shaded will show the cosmetic sketch thru all surfaces. Sketches that are behind other components should be displayed as hidden the same on a drawing as they do on a 3D model. Reference case CS149095 and the views attached.
