Similar to a Nastran GLUE interface, create an interface like the weighted link for surface to surface interactions on components that have a manufacturing tolerance gap. Intention is to have a model with a gap that behaves as if the material was there without going back and modifying all the cad models for the analysis. Rigid link will not behave the same if the gap is not very small.
