Create Boundary Blend feature using Creo Toolkit - C API
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
I am a Developer from Vestas. My team and I are building automation solutions for different design teams using Creo.
2. What version of Creo Parametric are you currently running?
We are using Creo 9.0.2.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
We have a requirement to create surfaces using Creo Toolkit. For that, the Boundary Blend option is the right fit for us. It'd be nice to create the Boundary Blend features using Creo Toolkit.
4. What is the use case for your organization?
We are migrating to Creo from CATIA for surfaces.
5. What business value would your suggestion represent for your organization?
As in the previous answer, we are trying to implement one CAD system around the organization.
2 Comments
achirila
Moderator
Status changed to: Clarification Needed
Hi @AbySelvaraj!
Thank you for publishing your idea.
However, you give the bare minimum of information. The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Here are a few examples of well documented ideas:
Merge occurrences in Compare to Part Structure too... - PTC Community
Subcontract enhancement - Ability to define contex... - PTC Community
Windchill preference values on user & container le... - PTC Community
Please elaborate within the next two weeks.
Additionally, I invite you to check out this topic where PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
achirila
Moderator
Status changed to: Archived
We are following up on our request for additional information on your idea. In the absence of further comments from you, we are archiving your idea. You still have the option to post a new idea with all the details required.
Thank you.
