Add the ability to create a GTOL with leader where the leader is perpendicular to the selected surface. Currently this is possible when selecting an edge as a reference. Please refer to the attached images, there are two GTOLs, one is created by using an edge and one is created by using a surface reference. The edge reference GTOL is exactly perpendicular to the edge, in the same way, we would want a perpendicularity icon when creating the GTOL by using surface reference.
