The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Create Option For Active Repeat Region
Currently in Creo 4.0 M110, if you have multiple repeat regions in your drawing you must select which region you want to use when placing balloons. I would like an option to set an active region so while placing balloons the software acts just like it would if there were only one repeat region. I believe this option could cut down on the number of mouse clicks, while reducing the need to switch between sheets if your regions are on a different sheet than which you want balloons displayed.
