I am using helical sweep command to create thread profile on a circular surface.
while creating drawing, I am unable to give radial dimension.
the arc is converted to spline after helical sweep.
In another part a cutout is created using the thread profile. we are unable to give radial dimension in this part.
I am currently using Creo 3, M110 date code.
Is there any way we can provide radial dimension?
