I need a STL or JT file for a EMM-Check. EMM-Check is a software for the evaluation of the field of view of vehicles. The surface represents the mirror glass and hast to be a surface, no volume.
Creo 2.0 can create an IV file from a surface and uses the chord height a parameter for the quality of the surface. That is exactly what I need for creating a STL file from a surface. Unfortunately Creo cannot load iv files.
