Add ability to save simulate results windows Templates for design studies that have multiple load cases where all or some of the cases are being shown in the results windows.
Imagine doing multiple iterations on the beam and needing to show all four results windows for each design iteration.
Currently you are not able to save a template containing all of the view shown below to be use for future runs where a part may be changed in the assembly. All 4 windows (load cases) need to be shown for reporting purposes.
This will help address the following error message..
All of the windows for inclusion in the template must be from the same study directory (Error Messag...
