Create a Chamfer option that will create geometry & dimensions as shown in image.
Currently in Creo 4.0 M030 when trying to create a chamfer referencing an edge of non-perpendicular surfaces you cannot get desired geometry or dimensions as shown in image. The work around is to create via other feature types (Revolve, Sweep, etc..). This process takes more time than desired. Please consider adding this functionality.
DesiredDesired
4 Comments
StephenW
23-Emerald II
Isn't your 30° and your 60° over-dimensioning your chamfer? Maybe I'm missing something?
Using Angle x D option in chamfer you get almost this exact result except for the "over-dimensioning"
WayneSchrock
Yes the 30° & 60° are duplicate, I want to be able to chose which dimension scheme I want to use while creating the chamfer. No, the Angle x D does not give the desired output, Notice in my images the chamfer is on an edge that was previously chamfered. Angle x D creates the angle from the existing angled geometry, not from the planar surface.
StephenW
23-Emerald II
Ah, yes, I see it. It's always the details that get you.
olivierlp
Community Manager
Status changed to: Archived
