Create a means in search tool to find/exclude components that have mechanism constraints. Usage: I currently use a search query to find all components/features in assembly that are basically not regenerated. However when using mechanism constraints that are fully defined to only allow desired movement the status shows as "Packaged". These components show up in my search query that is a indication to me that something is probably wrong. I must spend time evaluating each case.
