Create a method to execute a part/assembly in assembly using Current Values
Currently if a part/assembly has inputs and is used in a assembly without a executes for every input line you are prompted  "Choose source of values for Pro/Program inputs for model XYZ" during regeneration.
I would like a way in Pro/Program to execute the Part/Assembly and pass the source of values as "Current Values".
Example may look like:
EXECUTE PART XYZ
JOB_NO = JOB_NO
TOOL_NO = TOOL_NO
PRODUCT_DESCRIPT = PRODUCT_DESCRIPT
CURRENT_VALUES               All remaining inputs
END EXECUTE
and/or
EXECUTE PART XYZ
CURRENT_VALUES               All inputs
END EXECUTE
This will give the ability to not be prompted for values when regenerating an assembly that contains the component but does not control the component.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
