There are multiple standards for GD&T. While some are very similar (use many of the same symbols), there are symbols that one standard will use that will not be valid in another. The current Template Browser presents many symbols, but currently does not distinguish between the standards. As a result, it is possible for users to not only mix symbols from multiple standards on the same drawing, but it doesn't make it easy for administrators to enforce a particular standard for their users.
