Create a way to query the results of a simulation at a specific coordinate point
Currently, the model max of a Static Simulation results fringe plot can be reviewed and the coordinates at which that value occured can be seen.  But its impossible to review fringe plots for other quantities and query the values at the same locations without just guessing and clicking.
In othe words, If the Maximum Shear Stress fringe plot shows Model Max at point (0,1,0), the ability to reviiew the Max, Mid and Min Principal Fringe plots and query the results for the values at point (0,1,0) would be great.
This is impoortant because one approach of calculating the fatigue life of pressure vessels according to design codes is to do exactly as I described above, and input the Max, Mid and Min values into a formula.  Unfortunately, there is no way of querying that right now.
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
