Today if you need to make an isometric view at the drawing you can use two ways:
1 - make general view and rotate it (enter value of angle rotations - horizontal and vertical) in properties of view;
2 - make orientation in a model, save it and use in a drawing.
Both of way are non comfortable and long.
It will be cool to make an isometric view like projection view from any view, but keep the mouse (not to the right or to the left) to diagonal (angle) moving.
