1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
Mold Design/Build
2. What version of Creo Parametric are you currently running?
Creo 4.0 however can not do in Creo 8.0 either.
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
Create axis using existing coordinate system. Should be able to define which axis of coordinate system to use X, Y or Z
4. What is the use case for your organization?
Simplification, Less features required.
5. What business value would your suggestion represent for your organization?
Time savings.
