Create center lines, hole axes including proper display for radial holes
7 Comments
ptc-4226637
1-Newbie
Do you try to set drawing option radial_pattern_axis_circle to yes??
TomD.inPDX
Yes, this is the solution.  I voted for this because this option still requires improvements.  For instance, you cannot edit or otherwise work with the generated circle.
  • You should be able to blank sections of this so that only part of the shows in the case where you only have 2 closely spaced holes in one quadrant of the part.  Maybe a "partial" option.
  • Being able to create a drafting diameter dimension on the circle is also missing.
rnoah
8-Gravel
indeed !
where did you found this option ?
couldn't see it documented anywhere ...
TomD.inPDX
You really expect the help files to help
That's why we are here.
Thanks for taking the time to create all the great ideas, Rami.
Have you considered applying for participation in a technical committee?
You have a pretty good idea of what the software -should- be.
AndersT
3-Visitor
Using radial_pattern_axis_circle yes will give this correct display on pattern.
This display should also be valid when creating a single hole by Diameter type.
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
