With current functionality, it is not possible to specify a simplified rep of a model when you begin a new drawing WITH A TEMPLATE. It is possible to do this when you start a new drawing empty or with a format.
Please add the functionality to start a new drawing with a template using a model with a specific simplified rep (not the master rep).
See below discussion for clarification:
