Currently when performing "Save a Backup" on assembly with suppressed components, the suppressed components are not backed-up unless the component is in session. I would like an option to backup ALL components regardless. I have large assemblies with many suppressed components it is very time consuming to bring into session all the components just to have a backup of the current Assembly state. The backed up versions will be used for other design variations that use components that were previously suppressed.
Thanks for voting.
