At the moment the creating of SVG-Format in Drafting/Annotation uses the same Conf-File like DXFDWG ---> DXFDWG.conf.
But there is a problem with using Windows-Fonts the font name which must be used in DXF-Conf is the filename of the font.
Creating SVG you have to use the Name which is displayed in the software like Adobe-Illustrator. So it is necessary to make two CONF-Files which are
switched before creating DXF or SVG. In WIN7 a user without admin-rights cannot modify Files in the program-path.
