Creating a table from inspection dimensions in order to use it as a quality checklist
Most of the time when a product is produced there are critical dimensions that should be checked to see if they meet the required tolerances (as a quality check). These dimensions are often put in the drawing as inspection dimensions.
To evaluat if the model meets al the required tolerances it would be nice to have a table from inspection dimensions in order to use it as a quality checklist.
Similar functionality is already available with third party extensions, but not yet part of Creo Paramatric.
See for example:
http://www.inspectionxpert.com/Products/ForProENGINEER/tabid/81/language/en-US/Default.aspx
http://www.sf.com/sf/pdf/cad-cam-en/pe-inspect-en.pdf
4 Comments
TomD.inPDX
This would be nice to have but I suspect it can also be developed with the current product.  It is essentially a custom table parsed with specific dimensions.  I am sure these dimensions could be tagged in some way to build the table.
What really worries me is that -if- PTC would take this on, it won't be part of the core product but rather become part of the CAM package.
If this is important to your organization, I am sure there are a number of 3rd party developers that can do this for you.
PTCModerator
Emeritus
aparkar
6-Contributor
Designers specify inspection dimensions in CAD So their should be a way to pull Inspection Report which is used by Quality Team members as  Initial Sample Inspection Report (ISIR), This should be considered for Creo 6.0 OR Creo 7.0.
olivierlp
Community Manager
Status changed to: Archived
