In Creo 7 the marking of a selected component changes when you start using multibody.
Instead of showing the location in the complete tree, it only shows the feature in the body, tough sketches are not appointed to a body, this means of searching the model tree to find the feature and there the referenced sketch.
It could simply be solved by lighting up both the "extrude1" in de body part of the tree as well as the complete chronological part of the tree.
