Creo Direct:Countersink by Diameter .....
  For the Machine Module: I need to create a "countersink thru hole", but I want to input the countersink by DIAMETER, ( not by chamfer depth ). The reason is that I always know the countersink screw head diameter, but the chamfer depth is irrelevant to me. Also, the countersink screw head diameter varies quite a bit from manufacturer to manufacturer, and tolerance of manufacturing. Often I know the exact head diameter only after I have decidced who I will be ordering the screw from - and not before then.
  Therefore, the MOST RELEVANT INFO is the head DIAMETER of the countersunk screw - NOT the chamfer depth.
  Please incorporate the option to specifiy the countersunk hole in the Machining Module by countersink hole DIAMETER.
  Sincerely,
  Stephan Davies
2 Comments
ThomasKirkman
Most machine shops I work with go by diamter of countersink not depth
PTCModerator
Emeritus
Status changed to: Archived
