When a user add a custom Material Creo saves the new material in C:\ProgramData\Creo Flow Analysis\CustomMaterialsDataBase.smat. I need to customize the path of this file and I searched documentation but I couldn't find then I opened a case to ask it : C15618925
The customer support talked about article CS300506
Then I'm asking a config.pro / sup option to customize this file location, like for example:
pro_material_dir
pro_sheet_met_dir
pro_smt_params_dir
pro_group_dir
hole_parameter_file_path
sketcher_palette_path
pro_note_dir
pro_palette_dir
pro_symbol_dir
symbol_instance_palette_file
etc...
