Creo Illustrate - Item List visible in figure like a table
Would be usefull the possibilty to show Item List in the figure like a table or similar.
4 Comments
Ronan
 Hi Francesco,
that would be a nice evolution. Item list looks not complete yet.
PS: you should vote for your own idea!
Ron.
dgallego
Hej Franchesco, there is an option which works a little bit like that, it is called formatted pdf. You can publish an image and an item list in a table under the figure. There are still some problems, but PTC will take a look at those. I am waiting for their response. I will make you know if you consider this as an option.
Diego
rheinz
8-Gravel
having the same problem - Question to Diego - is the mentioned workaround become alive?
olivierlp
Community Manager
Status changed to: Archived
