I'm working as a technical editor / marketing guy and I happended to stumble uppon one big hurdle when I started working with creo Illustrate. I can't export vector formats for print. SVG is meant to be used for Web/display and therefore doesn't work for print. Shure it can be converted but that really messes up one's workflow.
Can we have .eps oder .pdf (but containing vector information) export in a future release? This would be a great step forward - the results look great so the only thing holding me from using them directly in my publishing software is that ther is no file format that allows me to directly import them and keep the vector files.
