Creo Mechanism Seperation Measure Needs More Capability
0 Kudos
To create a measure of separation, the only option is to make it between 2 points. This is much more restricted than measuring in Creo Analysis Measure, where you can measure between any datum points, planes, axes, coordinate systems, solid geometry, and surface geometry. If the mechanism has an important distance that changes as the mechanism moves, there needs to be the full capability to capture that distance.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
